HG motor mounts
2 Fingers
I'm slowly restoring a 1949 Oliver/Cletrac HG 42. I pulled the engine out to do some work to it and noticed that the front vibration dampening motor mounts have seen better days. I've found a source for them but they want $110 each and they don't look like the originals. Does anybody know of a better option?
I had the same problem. I purchased 2 inch square jewelry blocks from Amazon. They are hard black rubber. I bored a hole in the center and then turned them round
on the lathe. I finished by boring the center hole to the correct size. A little labor and about 20 bucks later, they work good.
(quoted from post at 17:14:05 11/21/22) I had the same problem. I purchased 2 inch square jewelry blocks from Amazon. They are hard black rubber. I bored a hole in the center and then turned them round
Thank Shooter, I'm a fabricator by trade so definitely sounds like something I'm capable of, and a lot more cost effective than buying the other ones.
