alberta dave
So the feeding tractor is having some clutch issues. Some years ago when the clutch was last changed it was making metallic rattling noises as well as feeling weak and ultimately your could smell and feel it slipping. I ordered up a HY Capacity clutch kit and installed it so the tractor got a complete new pressure plate, button clutch and throw out bearing.
Currently the clutch feels slow to engage and will slip when in higher gears but I do not hear any noises or smell any burning. The pedal feels pretty good but I am almost maxxed out on adjustment. DOES BEING MAXXED OUT ON ADJUSTMENT MEAN THE PRESSURE PLATE IS WORN OUT AS WELL OR IS IT JUST THE CLUTCH PLATE?
My question is SHOULD YOU ALWAYS CHANGE THE PRESSUREPLATE AND THROWOUT BEARING WHEN DOING A CLUTCH or are there times when just doing the clutch ok? Last time my pressure plate was very worn with the springs very loose and they were obviously the source of the rattle sounds I was hearing, this time everything sounds fine but the clutch is slipping when I put a load against the tractor. It is still working every day I just am keeping it in 3rd or 4th and using Low range when starting out.
I need to order parts soon and there is about $400 difference between the HY Cap kit and just a clutch plate up here in the far north.
