66 battery connections
theog9n
Hello,
We have an Oliver 66 and i noticed that the negative on the battery actually goes to the ground. i thought all these 6v systems were positive ground??
Do you have a alternator on it or generator? A alternator will be negative ground in most cases. A generator, check the tag on it to see if it the proper ground.
(quoted from post at 15:25:55 11/13/22)
Personally, I ve never yet seen a 6V alternator. Every one I have come across has been 12V or 24V on vehicles. I ve never seen a 12V positive earth alternator generator on a vehicle, but I know they exist(ed).
Perhaps the first question to the OP should be: is the battery 6 or 12 volts?
The alternator a 1973 Freightliner was a positive ground as well as the starter too. Been there done that, kept me on my toes for several years.
(quoted from post at 12:38:38 11/13/22)
I should have worded it different. Maybe converted at some time. Alt-Gen.
