wide front for 66
bv
what all other Oliver wide fronts will fit a Super 66 and does anybody on here have a good wide front for a Super 66?
They'll bolt on won't they? The spindles and tie rods will be bigger. They use 66 narrow fronts on 77 and 88 pullers.
Whether or not theyll bolt up I dont know. Kinda beside the point. The spindles on a 77 are at least 4 inches taller than a 66 wide front before you add in the 16 inch rims if you have the heavy hubs. So unless you get a 77+ wide front with lightweight 6 bolt hubs and you plan on doing a whole lot of playing around with tire/rim sizes to level the tractor back out youre going to be sitting in the seat looking at the sky. But I guess some people are ok with that.
