Oliver 77 / 310 repower...clutch?
Mortimer D
New User
I've read several discussions on how a 310 Waukesha will drop in to the 77 tub. What I didn't see was a whole lot of discussion on which bellhousing, flywheel, clutch parts to use. If any of you have any experience on what worked or didn't work I would like to hear about it so I know what to expect. Thanks
I don't know, but if you're building a puller, call Clutch Dynamics in Lansing Michigan. They make a double disc clutch for Oliver pulling tractors.
It will bolt right in, you will have to use the 77 or 88 bellhousing and a 88 flywheel, if you plan on revving it past 3000 you better use a steel flywheel for safety. you will have to shorten the driveshaft about 1 inch?? (not sure about that) or you can slide the engine forward about an inch and drill new holes. I have a 77 radiator that is modified for the 310 if you are interested let me know.
