Mike(NEOhio)
- Location
- Newbury, Ohio
I had the distributor out of some work and need to do a timing check. Couldn't see any marks through the hole so I took the lower cover plate off. I found the sticker and can see degree markings but can't make out any numbers or TDC marks. Pretty dirty in there. Is there some kind of TDC mark stamped into it or only the sticker? Not sure about the oil pump coupling either. The slot looks to be parallel to the centerline like it should but offset to the wrong side. That would be OK if it's at TDC but I can't be sure about that. I'm assuming whatever mark should be in the center of the hole.
