Not sure that's exactly what its called however it's leaking...There is a small external U shaped tube with fitting one either end like brake line fittings. The fitting closest to the engine screws in to a
brass 90 degree fitting that in turn appears to be threaded into a larger fitting that is part of the hydraulic block. That fitting appears to be about 3/4 around and that is where it it leaking. I've tried
to tighten the brass 90 degree fitting and will probably damage it if I try to go either way with it. Still not sure what/how to deal with the part that is actually leaking. I have looked at the repair manual
and it doesn't really show what I'm dealing with. It appears that you have to pull the motor to take this hydraulic unit off to get inside. hoping there is an external solution as I'm not really keen on
pulling the motor. Anybody have a solution?
