I've got a PTO issue with my 1650. It wasn't shutting off completely with the lever back, and so I backed off the PTO adjuster ring as well as adjusted the lever linkage. That did help slow shaft down with lever back, but backing off adjuster ring reduced the snap when pushing lever forward and recently I had PTO slippage when cutting some thick hay. I've tightened the adjuster ring to reduce the slippage, but of course the shaft is spinning now all the time. Some fluid/housing heat in the back as well.
Is there any additional adjustments that can be done or do I need to tear into the PTO clutch to see if discs are warped/worn? Thanks for the help.
