gen idiot light
I put in a new instrument cluster on a 550 and replaced the gen bulb. It works well, all the time the engine is running. Does not some on when the switch is turned to on. I have it hooked up at the switch per the
wiring diagram, but the photocopy is a bit fuzzy about the regulator. What should it be hooked to there or on the gen ?
The gen charges fine.
light idiot
