Oliver 88 hydraulics
J Hamilton
52 Oliver 88 hydraulics won't work unless engine throttle is at least 1/4 or more. Tractor has an aftermarket 3 point using an Oliver cylinder, and set of remotes. It acts the same with or without an implement. It struggles to lift a 6 foot bush hog unless at least 3/4 to full throttle. Do I have a weak pump or is there an adjustment I can make? So far I have changed the fluid, I used Hy-Tran and replaced the filter with an Agco filter.
