Hi:
The loader cylinder on our 1550 is leaking and I would like to take it apart to fix. The problem is that it is resisting coming apart. From what I can see there is an end cap and then a clip under the cap and then the unit should separate. The cap does not seem to be threaded as I cannot see/feel threads. The clip is broken and I was able to remove two sections of it but the rest is under the cap and I cannot figure a way rotate to get more pieces out.
Attached is a picture of the cylinder end.
Thanks for your thoughts.
