1550 draft control bearing and seal
matheus
New User
1967 1550 gas with leaking three point lower arm. Trying to replace the bearing and seal for the lower link support of the draft control assembly. Any direction or advice as to where to find these parts would be greatly appreciated.
So to be clear, you need to replace a lower three point arm seal and bearing?
If so, the Oliver/Agco bearing is 107533A which crosses to a McGill GR32, and you can find McGill NOS on eBay for much less than Agco or a bearing shop. The seal is 107534A which crosses to a readily available SKF/CR 23061.
(quoted from post at 13:37:06 05/26/22)
Thanks so much scootergmc, that is exactly what I needed. Found and ordered the parts. What a great forum!
