Had the injection pump rebuilt on my 1650 and installed it this afternoon. After bleeding, engine starts right up with an injector line cracked and immediately revs way up out of control and doesnt respond to throttle. Stopped engine and tightened lines. Start up, same thing happens. Engine runs faster than full throttle for a couple seconds and then I shut it down.
Rebuild shop isnt open until Tuesday. Need the tractor in the meantime to grind feed. Any ideas?
The throttle lever was tied up with the shaft seals on the tie. Had to untie to take off the seals before mounting. Its spring loaded so I bet it slid forward. When I called Shop owner he mentioned the throttle lever holds part of the governor in place and shouldnt be moved until pump is installed. Appreciate any advice for a guy who was too dumb to know that in the first place.
Tractor was running well beforehand just leaking badly out of the stop lever shaft on injection pump.
Thanks
Aubrey
Thanks
Aubrey
