770 pto lever for power traction hitch
Rice
New User
I purchased a 770 last year and have now put on the power traction hitch. The pto lever i have is not compatible. Does anyone know where I can find a lever that works with the power traction set up?
Thank you,
Rice
Good afternoon, I purchased a 77 with the
hydra hitch on, but no pto lever, my
father in law helped me make the lever out
of an 770 gear shift. Lots of heat torch
and a lil welding, and it looks like his
880 hydra hitch, pto lever.
I have an 880 power traction hitch now,
and it's pto lever is the same.
Maibach in Ohio
Welters in Verona Mo
If you want, we can get measurements for
you in the near future.... GG Wes
I Installed a Hydra Hitch on My 77 Standard and had the same Problem. Lack of a Lever. Since then I have found everything except the Lever that Pins on to the Engagement Shaft (PN 100800A). Any chance You found an Extra or are still on the Search?
Thanks.
