Our 2-105 hydraulics are acting up. Tractor normally runs the discbine and round baler. No issues with raising or lowering the discbine or opening and closing the rear gate on the round baler. Cylinders open and close normally. This spring we decided to do some tillage on rented ground and used it to run the 5 shank chisel plow. There were no issues raising or lowering the chisel. But when we put the 14 foot disc on the 2-105, it raises it ok but when you lower it, the hose that sends flow back to the tractor pops out of the coupler( we normally set up our connections such that the remote lever is pushed to the rear to raise and forward to lower). It does this on both outlets. The outlets are adjusted for lowering the same as our 2-85 and our 1750. These tractors have no issues with the hose popping out of the coupler when raising and lowering the disc. We have not reversed the 2-105 remote operation to check what happens then, we will try that the next rainy day.
Does anyone have any idea what is causing this? Thanks.
