susandiane
I'm trying to hook up the generator idiot light on a 1963 550 Oliver. I have the manual diagram, but I'm not sure if my old eyes are seeing things right. Beginning with the light, which is grounded to the instrument
cluster, the power supply wire appears to go to G on thge voltage regulator, then to the A terminal on the generator. I don't see a G on the regulator that's on the tractor. If G means ground, can I ground it
to a regulator mounting screw, or do I need a different regulator? Thanks!
