Too thick to navigate and too thin to plow
super 55
Location
Whonnock BC
I had to get my Super 55 towed out by neighbour and his truck with a winch. Looks like I'll have to wait until the field dries out a lot more. One thing I can do is fix the three point lever. It either wants to be fully up or fully down. There is no resistance on the fibre disc. It appears the threads are stripped on the shaft, that's why it won't tighten down.
(quoted from post at 02:58:21 04/26/22) I had to get my Super 55 towed out by neighbour and his truck with a winch. Looks like I'll have to wait until the field dries out a lot more. One thing I can do is fix the three point lever. It either wants to be fully up or fully down. There is no resistance on the fibre disc. It appears the threads are stripped on the shaft, that's why it won't tighten down.
Is it the shaft or the nut stripped? Both likely easy fixes with the latter being the easier of the two?
It's the shaft. I sort of knew that it was stripped when I had my tractor stripped down, and basically forgot about it. Hoping it's an easy fix. I can't recall if the shaft is steel or aluminum. I'll
get to it later today or tomorrow.
