young tractor
Hi guys thanks for all of your help on the previous post. I originally pulled the tractor in the shop to reseal the power steering cylinder. Its leaking. I watched the Chris losey video on how to do it. He mentioned that on Perkins engine that the crankshaft pulley needs to be removed to get the steering cylinder out to rebuild. Is the front crankshaft pulley like my 1755 where the seal rides on the crankshaft pulley. Im nervous to pull the pulley and then put it back together and the crank seal then leaks. Is there any way around removing the crank pulley? Also am I better off unhooking the oil cooler lines and removing the oil coolers with the radiator or can I in bolt them from the radiator and lay them down. Thanks for your advice.
