The PTO on the 550 I salvaged a year ago arrived with a PTO fully engaged and the activation arm freely loving without effect. The PTO is running full time. There were problems with it that took priority but now I'm thinking it is PTO planning time. I have done nothing with the PTO yet, but the previous owner said they had redone the PTO, used it but it quickly stuck in this run position. They also said it had a bad hydraulic leak and had to be refilled regularly. They refilled by keeping it visible at the fill point, I drained about six gallons from the Transmisson to get it to quit pouring out the inspection plug. So, I assume they kept the entire clutch cavity full of transmission fluid and soaked the disks. I figure a split is inevitable but some of you folks might have had a similar problem and have some alternate ideas.
