Oliver 550 Electrical
LBMays
New User
Would like to know the procedure for converting a 12-volt positive ground to 12-volt negative ground on an Oliver 550 tractor.
For what purpose? I don't think the cluster gauges will work with negative ground unless you replace them.
(quoted from post at 15:17:19 01/20/22) For what purpose? I don't think the cluster gauges will work with negative ground unless you replace them.
The problem is that I am unable to get a positive ground cluster gauge, they have been on back order for 2 to 3 months. At this time it seems unlikely that I will be able to find one. I have a new negative ground one. The old cluster gauge is not repairable.
I have a new 550 cluster guage positive ground. I bought it for my brother-in-law as a gift when he got his
tractor, then he had the tractor switched over to negative ground by his mechanic. If you are interested, call me.
812-six three 9- six five three six.
(quoted from post at 16:26:59 01/20/22) I have a new 550 cluster guage positive ground. I bought it for my brother-in-law as a gift when he got his
How much are you asking?
When it comes right down to it, I think all you have to do is swap the battery cables to the other posts and polarize the
generator. I don't know about the wires on the coil. You might have to switch them, but I'll defer to somebody else on whether or
not you have to do that.
When I got my 550 it had been converted to negative ground and the cluster gauges did not work,
had to replace it with a negative ground specific cluster.
