A White 4-175 has come available. Owner says that something sheared in transmission. Neighbor of mine knows the Cockshutt and White tractor quite well and has several of these units. This is in Alberta so the Olivers are painted red around here. Always wanted a 4-225 but you are likely to find a unicorn. If the tranny is not too hard to fix would you find a 3208T to repower with or a 8.3 Cummings like out of a Workhorse series of tractor? It has 5800 hrs so that is likely the lifespan of 3208 anyways. The 4-175 has only 126 drawbar hp which is less than my Allis 8070 and would like a bit more power. Would the tranny and diffs hold up to around 250 engine hp.
