My 1955 has had a rash of hydraulic hose and fittings problems. I finally got them fixed and got my beardless wheat patches plowed and planted. I still had a hydraulic leak from the steering line under the cab and deck near the pressure valve below the hydraulic pump. After I finished, I discovered the 90 degree swivel piece was leaking, so I replaced it. Afterward I discovered that the hose assembly connecting the pump to the pressure valve had suddenly developed a leak. Have any of you out there ever changed this hose? How do I do it? I feel that the other 3 smaller hydraulic hoses need to be disconnected from the pressure valve in order to reach the hose to be replaced. Any advice would be greatly appreciated. I have every official Oliver book I could find for 1955's. There is nothing in print that I can find explaining how to do this job. Any help would be appreciated.
