swindave
does any one know how many 2255 tractors were made?
were they good tractors in their day?
ive never used one, but always liked the way they look
thanks
TractorData.com - information on all makes and models of tractors
Tractors > Oliver > 2255
Tractors
Lawn Tractors
Compare
Articles/News
Tractor Shows
Contact
Oliver 2255
Oliver 2255 tractor photo
1972 - 1976 55 Series
Row-Crop tractor
Overview
Engine
Transmission
Dimensions
Photos
Tests
Production:
Manufacturer: Oliver
Factory: Charles City, Iowa, USA
Total built: 2,160
Original price (USD)
$18,500 (1976 )
Oliver 2255 Engines:
Caterpillar 9.4L 8-cyl diesel
Caterpillar 10.4L 8-cyl diesel
full engine details ...
Capacity:
Fuel: 35 gal [132.5 L]
30 gal [113.6 L] (cab tanks)
78 gal [295.2 L] (fender tanks)
3-Point Hitch:
Rear Type: II/III
Control: draft control
Rear lift: 6,000 lbs [2721 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 1000
540/1000*
Dimensions & Tires:
2WD Wheelbase: 108.3 inches [275 cm]
4WD Wheelbase: 83.5 inches [212 cm]
Weight: 16500 lbs [7484 kg]
Front tire: 11.00-16
Rear tire: 18.4-38
full dimensions and tires ...
2255 Serial Numbers:
1972: 235-598
1973: 237-210
1974: 244-825
1975: 258-472
1976: 266-683
how to read serial numbers...
Oliver 2255 Power:
Drawbar (tested): 115.35 hp [86.0 kW]
PTO (tested): 146.72 hp [109.4 kW]
power test details ...
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: power
Brakes: hydraulic disc
Cab: Open operator station. Optional ROPS. Cab available with optional heat and air-conditioning.
Hydraulics:
Type: closed center
Valves: 1 to 4
Pump flow: 20 gpm [75.7 lpm]
Battery:
Number: 2
Volts: 12
Page information:
Last update: May 3, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: [email protected]
©2000-2019 - TractorData™. Notice: Every attempt is made to ensure the data listed is accurate. However, differences between sources, incomplete listings, errors, and data entry mistakes do occur. Consult official liter
In my honest opinion is that cat engine was a pretty short lived engine, it wasn't anything like the 3406C or any of the 6 cylinders cat', if it didn't have fender tanks, you weren't going to get much done!
(quoted from post at 19:41:47 07/04/20) In my honest opinion is that cat engine was a pretty short lived engine, it wasn't anything like the 3406C or any of the 6 cylinders cat', if it didn't have fender tanks, you weren't going to get much done!
I had a 3208 that went over 21,000 HRS before it broke a piston.
