Recently acquired Super 55 has a 12 volt conversion using a Delco 10S1. This has one heavy wire running to main post, then a wire running from main post to right tab terminal where regulator plugs in. Also has a resistor from the right tab terminal to left tab terminal right beside it. My problem is that it charges just fine but that resistor is constantly warm to the touch all the time and apparently runs battery down over time. What do you folks suggest should be changed? I have not taken alternator apart to check status of alternator internals just think needs to be possibly wired differently. Any help appreciated, Thanks.
