alejandroflores
New User
My Name is Alex and I am trying to help my father-in-law get his Crawler going and have some questions that hope you can help.
It is and OC3 with an XB4000 distributor. Found the distributor bad. Changed the coil and condesor per spec and it worked and is spark is seen on all 4 plugs. Followed the Zimmerman tech tips about timing. Believe I got that correct.
When I didn't get compression on #1 with the thumb over the plug hole I got a gage and found that a hand crack yielded no pressure but a rev or two with the starter yield 30 lbs.
Occasionally I will get a back fire through the carb...but nothing that sounds like starting.
Should I go after timing or compression?
I read a post that talked about filling the pistons up with ATF and soaking for a week. Wasn't sure I understand how to do that and then how to get it out.
Seems like a have spark, tried starting fluid, inthink I have timing... other then an occasional smoke out the exhaust... I have nothing to show for it. Any help would be greatly appreciated.
