Cockshutt 540 Problem
Traditional Farmer
Location
Virginia
Traded for a pretty nice Cockshutt 540 everything works but it has a loud screech coming from the clutch/front shaft area.Sounds like maybe a bearing or the PTO and drive shaft rubbing each other? The PTO and hydraulics work so the shaft is turning and the tractor drives fine.Any ideas? Also the noise is constant in neutral or moving,clutch in or out.
Had the same problem with an 1850. The sleeve that the throw out bearing slides forward and rearward was dislodged from the bell housing. I turned it end for end and pushed it back into the bell housing. I had to build a pattern jig to get it in position. Needs to be at a right angle to the surface of the bell housing in both directions. Then it gets welded with a special rod. If you have too much damage this won't work. Ours has been back in service for about 10 years and it is a loader tractor. Lots of clutch use. Good luck. Let us know what you find.
