CR rake bearing removal
Alan K
I have a CR MM rake that I need to remove one of the end caps from the steel disc to repair one of the steel tubes. I think the earlier Oliver rakes might be the same. Can a little heat be applied to the nut for removal without damaging anything in the bearing assembly?
Do you happen to have an actual picture of the bearing assembly its self? I have a parts book but it is kind of crude pictures lol.
Luckily, I got them loose. I used a wrench and hit the end with a deadblow hammer. Came loose. I was afraid they might start turning and would end up splitting the nut to get it apart.
