henryv11
Its going to cost so much to repair the hydro power on my 1650 diesel they said it would be better to replace it with a over/under as they are more available.
Justin Meyer in Minnesota may have one for sale or there is anther guy that salvages tractors and parts them out. Maibach tractor in ohio might also have one. I would not change it over to the 2speed. I think you will like the 3speed better. Would you try and rebuild it yourself? I am going to take one apart in the next few weeks.
Mike that was mine out of a 1650 that threw a rod. I had advertised it on here years ago and didnt have any response. I was trying to clean up around here and the fella showed up on time and I loaded him up.
My Hydro power is completely shot needs new shaft and all. I just wondered if there would be a lot of modifications to change it over to the over/ Under. Thanks for the reply's
Mike it has been discussed on here before. Unit from a 1650 1655 or White 2-70 will work. Thats a Hydra Power drive in Connecticut.
