Dave anola
New User
Hello there
Just registered
I have an Oliver 1650 Wheatland style/no 3 point gas powered with a loader
was recently using the loader to lift 1200lb (just a guess) and it can lift the weight without issue
The problem I'm having is with the loader at 3/4 height and starting to lower it down it just stopped and would not lower
I curled the forks and dropped the load. Still won't lower so I ended up cracking the line and bleeding it down
After some research it seemed like maybe the couplers could cause this flow restriction in one direction New Pioneer couplers same issue
Today I took the valves out and disassembled the left hand valve. I see no broken springs, plungers, dirt, issues at all
The loader was lifting and curling still just will not lower when it usually has downforce
Sorry for the long post but I'm just not understanding what happened or how to proceed from here
Also it had some chatter when lowering heavy loads and was smooth empty
Thanks in advance Dave
Just registered
