1850-1950 rear end and radiator
rrman61
A poster on tractor talk has a 1850 with no engine.I
have a 1950 with a seized rear end.are the rear
end/transmission the same.and radiator?
Maybe: Do you have all 9 digits of the serial numbers for both tractors. On the radiator I can not access my parts book. Send me an e-mail. J.
Dont really know anything about his 1850 at this point Ill have to see what hes got and get back to you.
The rear ends are different, but could be interchanged. The 1950 has a 3-disc brake, while 1850 has 2. Also 1950 has a provision that prevented ring gear deflection which was not in the 1850.
Yes the bottom hose on an 1850 with a Perkins is on the left side of the engine when you are sitting in the seat looking forward.
We had a similar problem with our 1950. Found a 1950T with a bad motor and basically split both tractors and put a good one back together. Haven't had any real issues the the 1950T rear end. The 1850 rear end may be a bit more beefier if it is a late model 1850. Another individual and I have been discussing this since we both have later model 1850's.
