Oliver 1800a gear jumper
Sam WI
New User
I have an 1800 checkerboard that jumps out of 4th and all the gears in that range. 4th being the most common to jump. You can hold the shifter in gear and it stays in gear just fine. I pulled the top cover on the transmission and don't see anything obviously wrong inside. Any thoughts would be appreciated.
I started working on Olivers's when they were new. I will need a serial number and a phone number. My e-mail should ne open.
The coupler on the top shaft has some wear
between it and the fork. This should be the
coupler that engages high and low range
correct?
