Freeze plugs in a 265 gas?
LandonT
Hi all, will visit the 880 this weekend, we were shocked by the cold snap a couple weeks ago and I'm worried what I will find. Do the Oliver engines have freeze plugs? If it froze, where is the most likely place to find a crack?
Thanks.
Just a little FYI here...
Technically, they are called soft plugs. The holes were put into the head to remove the sand when they were cast at the factory and the soft plugs are just there to close the hole.
If you've had a hard freeze, USUALLY the "freeze plug" will not save the head from cracking.
Good luck.
Thanks, all, had at least one gallon of fresh 100% antifreeze in, possibly two, never expected to see single digitsw here.
