Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
1850 engine swap ??
Author |
[Modern View] |
herk
02-22-2021 19:50:56
Hello fist ? I twisted off one of the center manifold bolts , both center bolts are seized to the manifold any suggestions?? Second ?? the oil filter housing is on opposite sides of the block, can this be just switched side to side or do I need to do some thing under the oil pan?? 3 rd ?? some say I can use the oil pan from the combine , a friend used the combine pan on his 1850 , I will know more when I get the engine out of the combine , Thanks Bryan
ziffel
02-23-2021 07:10:36
Re: 1850 engine swap ?? in reply to herk, 02-22-2021 19:50:56
If any of the bolt is sticking out from the head, Heat them up, pour some cold water on them while still hot. That may help. We used to loosen brake bleeders that way. But the way I have had the best luck is to slide a not over the broken piece and weld it using a wire welder. Easy to control the welding process that way. I have done the same thing when broke off flush with the head. Using a wire welder and little short bursts try to get the weld build up to stand out from the head surface. Then place a nut over it and weld it to the weld build up. The heat generated welding helps a great deal.
rrlund
02-23-2021 07:22:38
Re: 1850 engine swap ?? in reply to ziffel, 02-23-2021 07:10:36
Arnie, have you ever tried a flat washer then a nut? I've had fantastic luck welding a flat washer to the broken bolt then welding a nut to the washer. You can weld around the outside of the nut to get more surface.
ziffel
02-23-2021 07:34:42
Re: 1850 engine swap ?? in reply to rrlund, 02-23-2021 07:22:38
No I haven't. I'll remember to try that. Before I got the wire welder I used to that with 1/16 rod and a stick welder lying on my back under a Chevy pickup trying to keep from having to take the exhaust manifolds off. I don't do that no more. Too old. Thanks for the tip.
rrlund
02-23-2021 04:33:14
You have to use the tractor front engine cover because the motor mount slides around it. Because you used that front cover, you need the tractor oil pan. The tube on the tractor oil pump has to be used to get the oil to the other side. You might need the whole pump, I don't remember. You'll need to put a pipe plug and soft plug in where the combine filter base was. You need the tractor tappet cover, rear side cover, water pump, manifolds, injector pump linkage and injector lines. There might be more, but it's been a few years since I've done one and the memory is fading. Pretty much just plan to strip the combine engine down to just the block, crank and head and replacing everything on it with parts from the tractor engine.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
