88 motor swap
super99
I got the 77 motor out of the 88 today. I had to loosen the instrument panel and move it a little in order to get the gas tank off and then it came right out. Gonna have to cut some off of it and weld it back on. Belt pulley is stuck, I tried to turn it with a bar and no go. Thinking about filling it with panther pee and let it set a bit and see if it breaks loose. I don’t see a drain on the belt pulley, is there one?
