Oliver oc-3 pto alternator
I put a 3 wire on the OC-3 I had but that was years ago and I have sold it since
The one- wire alternator has a "self-exciting regulator" so thus needs only one wire and looks cleaner and easier to install.
The draw back with this alternator is you need rpm to make it charge; if your going to idle around much and no rpms then the 3-
wire is the way to go. My opinion.
Thanks, anyone have any luck getting one? Been have some trouble getting one. The last one seems a little big.
I can buy a 3 wire alternator all day long from my local O'Reilly's for around $50 plus a $10 core
I converted my early OC46 (same engine as the OC3) using a small Denso alternator that is common on sub-compact diesel tractors such as JD. It is very small and fit in the OC46 engine bay unobtrusively. I followed instructions posted on this forum probably 10 years ago, he also posted them on the old Cletrac forum. My conversion has been working perfectly for around 8 years.
He has a YouTube video of the finished conversion. I found an old bookmark of what I think that I used, got it from Rareelectric.com.
https://www.youtube.com/watch?v=B37YWbXImTE
https://www.rareelectrical.com/i-26880810-new-alternator-fits-john-deere-tractor-3120-3320-3520-4200-129423-77200-101211-1170.html
Here is an earlier thread on the conversion.
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=111792
I installed a Delco 10SI alternator in my OC-3 a while ago using the attached schematic. Low RPM's were never a problem. Also replaced the
magneto with a Farmall H distributor. Worked great, allows you options for a high output coil. Have since sold the machine.
Did you have to build brackets for the conversion? Trying to figure out how to mount one on my 1951 HG-68 Crawler
Ron
We ended up not getting it on, we could not find a way to put it on. The old generator ended up ceasing up. The person that owns the crawler ended up scrapping the old generator. We ended up just putting a belt on that fit between the fan and crank pulley. Maybe we'll do something down the road.
(quoted from post at 07:44:47 01/27/21) We ended up not getting it on, we could not find a way to put it on. The old generator ended up ceasing up. The person that owns the crawler ended up scrapping the old generator. We ended up just putting a belt on that fit between the fan and crank pulley. Maybe we'll do something down the road.
Thats my problem also. My 6V generator is fine. I am looking into converting it to 12v. It will give me all I need. I keep a trickle charge on it all the time anyway so I should be fine.
(quoted from post at 13:53:48 01/27/21)
He'll probably do the same with the charger.
