Tnwhite244
New User
Oliver 550 4cyl Diesel/Smith loader 2-44 L, and a Mighty Hoe attachment.
I have milky, turbitity looking (bubbles) in fluid, both Tranny and hydraulics.
Any additive to deter this moisture issue?
Suggestions on the best way to drain hydraulics system?
Is it like brakes on a car furthest point?
I have seen posts suggesting you run 5-5gal buckets of fluid through system? cant afford that method!
Tranny drains, there are two 1/2 drive recessed plugs on bottom of the case of the 4sp shuttle shift tranny.
Are those the drain plugs? and to refill use 80w90?
where is the fluid fill overflow plug located, any pics?
is it on the clutch side or brake peddle side?
And is it recommended to flush tranny? with what?
I've read Kerosene flush?
thanks for your help and knowledge
