Hydraulic fluid
Chris Ford
New User
I've got a late model 1650. Has gotten water in hydraulics any tips on getting it all out without having to go through 5 5 gallon buckets full cycling new through the system
If you're not up for taking the whole housing off and cleaning the pan, pull the valve unit off the top and you can see much of the bottom. Suction it out with a flexible hose pushed around the bottom. A siphon spray gun will work but you can just blow compressed air across the end of the hose and it will pull. A little water will not hurt and will be driven out with use. This is what mine looked like. I took everything apart except the plugs in the servo valve, cleaned it and replaced all the O-rings.
