super99
I had 2 Drs. appointments am and the snowmagaden is coming, temp was 33, so I worked on the 88 this afternoon. I’m ready to lift the motor out except for removing the clutch rod. It was a bear getting the bolts out of the driveshaft coupler but I finally got them loose and slid ahead. Took the carb off of the incoming motor, it needs a good soaking and a kit. The belt pulley is definitely coming off!!!Here’s a few pictures.
The power steering has been leaking for quite a while so I’ll see about fixing that also
