Jared Chaddock
Ive been working on our 1963 Oliver 550 diesel. It has the roosamaster pump. The thing starts great, and now that I got the manifold heaters working it will start
at some pretty cold temps easily. The problem is, the exhaust never clears up. Diesel smoke, not oil. This weekend I replaced the injectors with a set I tested
and reset the pressure and while it runs a bit smoother at wide open it still never burns clear. Looking thru the injector ports, the power cells looked good not
all carboned up, and I drained the fuel and replaced it with fresh, along with the all new filters.
Not sure what else it could be.. If it didnt start so easy and run so well Id say it was tired. Anyone have any ideas? Thanks in advance!
