whats your oliver plow model?
swindave
if you ever had, or have , or used a oliver plow,
what model is it?
i have a oliver rooster comb 2 bottom plow,
and a old horse drawned 1 bottom walk behind oliver 177?
whats in your barn?
I don't even know where to start. I guess this is a 588? It's decaled as a Case.
I've got more horse drawn plows than you can shake a stick at. Too numerous to even try to remember model numbers.
I've got a two bottom Plow Master here and a Dearborn 2 bottom with Oliver Radex bottoms. In the past, I've had a 3 bottom 314 gang plow, a 3 bottom trip beam pull type, don't remember the model off the top of my head. A 4 bottom pipe beam pull type that I put an add on bottom on and made a 5 bottom. I had one of those three bottom semi mounts that was made for the power traction hitch, a 2 12 rooster comb..... I don't know, those are just the ones that come to mind right off hand.
I have a two bottom rooster comb, a 508, and a 548.... in the past we had 565 and a 4240 and a 4440 pipe back plow ...that's all I can think of now
Growing up I remember having a couple of the 3-14" bottoms rooster comb plows. Are those what they called Plowmasters? Model 100? Those were the days I'd be riding on the old 88 with my father and he would slide off the seat and let me steer the tractor for a while. At some point there was another 3 bottom trailing plow that had a hydraulic cylinder to raise it. There was also a 2 bottom of the mechanical lift type that I remember plowing with our old 70 one day later on when I was old enough to drive on my own.
We also had a two bottom 6240 roll-over plow. I only know the model number because it was shown in the mailbox section of Oliver Heritage magazine Aug/Sept 2020 issue.
6 or 7 2 bottom plowmasters.
1 3 bottom plowmaster.
Parts to a horse drawn 3 bottom orchard plow
2 bottom hydraulic 4240
3-14B hydraulic lift
2-14B trip converted to hydraulic
4 bottom 5440 pipe plow with the add on bottom to make it a 5 bottom, currently off.
5 bottom 575 hydraulic reset with the add on bottom to make it a 6, currently off. And a 5 bottom parts plow.
7 bottom 565 cushion trip on land hitch.
Complete working model 21 two way plow on steel.
2 bottom 3240 three point.
Model 134B trip on steel.
I think that’s all of them.
Have a 3 bottom rollover sold as a ford. 4 bottom 5440 4 bottom 4440 4 bottom 4340 3bottom 4340 2 3 bottom 4240's 1 hyd. 1 trip lift. 2 bottom 4240 with the small tail wheel. 7 differant 2 3 bottoms that I always thought were variations of the plowmaster 100; not so sure about that. one pictured has an adjustable frame.
Here in western PA we have a 508 4-16 spring reset, a 508 3-16 cushion trip, a 4230 3-16, a 3242 2-14, and a 348 3-16. The semi-mounts are just taking up space as are the 3242. The 4230 is used on plow days. The plow we use when we do occasionally plow is the 348.
Put a lot of miles on a 565 4x16 behind a 1650 Diesel. I would like to find a 348 or similar, 3 point mounted with 3 or 4 18" within a reasonable distance and price.
I have a TNT rooster comb that has never been in the ground. Several plow masters and a 2 bottom that was made to match the Fordson.
Jim
We had customer who had a 3 bottom Oliver roll over behind a 6 cylinder 720 John Deere. He had a V-4 Wisconsin mounted on the side of the 720. When the going got tough he would engage the clutch on the Wisconsin giving him the extra pulling power. Later on he got a 5010 or 5020 don't remember which with a 318 Detroit. It would handle a 5 bottom Towner roll over plow.
