Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Oliver oc-3 pto alternator
Author |
[Modern View] |
mikewood869
01-12-2021 17:13:15
Anyone ever get a one wire alternator for a Oliver oc-3?
Jethrow4
01-13-2021 06:41:26
Re: Oliver oc-3 pto alternator in reply to mikewood869, 01-12-2021 17:13:15
I installed a Delco 10SI alternator in my OC-3 a while ago using the attached schematic. Low RPM's were never a problem. Also replaced the magneto with a Farmall H distributor. Worked great, allows you options for a high output coil. Have since sold the machine.
MikeS55d
01-12-2021 22:31:42
Here is an earlier thread on the conversion.
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=111792
MikeS55d
01-12-2021 22:22:24
I converted my early OC46 (same engine as the OC3) using a small Denso alternator that is common on sub-compact diesel tractors such as JD. It is very small and fit in the OC46 engine bay unobtrusively. I followed instructions posted on this forum probably 10 years ago, he also posted them on the old Cletrac forum. My conversion has been working perfectly for around 8 years.
He has a YouTube video of the finished conversion. I found an old bookmark of what I think that I used, got it from Rareelectric.com.
https://www.youtube.com/watch?v=B37YWbXImTE
https://www.rareelectrical.com/i-26880810-new-alternator-fits-john-deere-tractor-3120-3320-3520-4200-129423-77200-101211-1170.html
mikewood869
01-12-2021 19:48:55
Thanks, anyone have any luck getting one? Been have some trouble getting one. The last one seems a little big.
old
01-12-2021 20:39:12
Re: Oliver oc-3 pto alternator in reply to mikewood869, 01-12-2021 19:48:55
I can buy a 3 wire alternator all day long from my local O'Reilly's for around $50 plus a $10 core
banjoman09
01-12-2021 19:40:50
The one- wire alternator has a "self-exciting regulator" so thus needs only one wire and looks cleaner and easier to install. The draw back with this alternator is you need rpm to make it charge; if your going to idle around much and no rpms then the 3- wire is the way to go. My opinion.
old
01-12-2021 18:07:48
I put a 3 wire on the OC-3 I had but that was years ago and I have sold it since
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
