Company Logo Shop Now
1850 pto
young tractor
01-08-2021 14:55:58
Hi guys last fall I was on here asking about switching my 1850 diesel to 1000 rpm shaft. I made the mistake of shifting it while the 540 shaft was in. Someone on here said a pin falls down and makes the little shifting plunger stuck in place. Right now the pto doesn’t work. The shifter is stuck in no mans land. I got the whole pto unit out of the tractor and thought I would ask before tearing it apart. Can you guys give me a simplified way to go about fixing it? I assume I separate the outside housing from the inside. Is there anything I have to take apart before that? Then will it be obvious once I get in there? As always I really appreciate all the help you’ve given me over the years. You were a big part of helping me get started farming with Oliver’s. This tractor was in the Oliver magazine a couple years ago. It’s my favorite tractor on the farm.
J. Schwiebert
01-09-2021 07:07:27
 Re: 1850 pto in reply to young tractor, 01-08-2021 14:55:58
While you do that you need to rework the clutch. Send me an e-mail.
NYOlivers
01-08-2021 17:50:25
The best thing is to have a service manual. Its really not all to hard to take apart. Go on youtube and search Chris Losey "oliver 50 series pto rebuild" he has a few videos on rebuilding one.
young tractor
01-09-2021 17:39:27
 Re: 1850 pto in reply to NYOlivers, 01-08-2021 17:50:25
Thanks guys. The videos really helped. I got it apart. The pin just hung up. I’m putting all new seals in it now that I’m that far. I don’t think the plunger popped forward when I pulled the 540 shaft.
NYOlivers
01-11-2021 11:07:02
 Re: 1850 pto in reply to young tractor, 01-09-2021 17:39:27
Get in contact with J. He has the info on the pto clutch parts that need to be machined to stop the drag and constant spinning of the shaft. He helped me out with it.
J. Schwiebert
01-09-2021 20:12:08
While you are there have the clutch machined a little. It will prevent that drag on the clutch disk!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
