2-135 pto question
pms
Looks like it is 1000 rpm pto only.Was
hoping someone with a 2-135 could verify
this for me.Thanks Paul
Yes I know thats a 1000 rpm shaft.Most of the 2-135s had the 540/1000 rpm setup.Just can't tell if that's a 540/1000 rpm unit or just 1000 only.
Thanks,Paul
On the dual speed units you swap out shafts to go from 1000 or 540.Looks like you can't swap shafts on one in the picture.
Paul
If you remove the four bolts holding the pto shield on and you can pull the shaft out with the bearing then you have dual speed pto. The 540 shaft is longer and engages on a different splines then the 1000 pto. If you can’t pull the shaft out then it’s single speed only.
You've got it. Hopefully somebody hasn't punched that little plug out so the oil won't gush out like a new milk cow. Mine's still in there. I don't think I get enough oil out of it to fill a 10cc syringe when I pull the shaft out.
Was going to look at tractor to buy.Asked owner to snap a picture of pto to verify if its a dual speed unit.Couldn't tell from picture if those four bolts are holding a plate that retains pto shaft or if that is part of the casting.Never owned a 2-135 so can't tell from picture what I'm looking at.So you guys are say that's a two speed unit?Excuse my ignorance lol.
Paul
