steering wheel removal 55 series
rhomium
I'm trying to remove the steering wheel on my 2255 and with the telescopic column, does one use a 3 jaw puller pushing down on the center shaft/button? i have removed the center cap and the nut. I don't want to wreck the telescoping mechanism. Or can I tap the steering wheel from the bottom and it will pop off? Any tips would be appreciated.
Thanks in advance.
If you can hit the steering shaft with a blunt end air chisel lifting up on the steering wheel without hurting anything the wheel will usually come right off.
I was able to get it off by putting a
socket over the telescope button and then
using a puller. Thanks for the help.
