Hello I had the damper on my 850 massey combine separate . I found one a massey 750 same
engine 354.4 both have the 3 bolt mount, the belt pullies line up, the one from the 850 is
made different( 2 piece rubber mount) then the one from the 750 ( one piece solid ) also
about 2 inches larger in diameter a friend has a white 105 ( I think )different again from
these 2, my ?? is can I run a different damper then what it came with << Thanks Bryan
