Company Logo Shop Now
Oliver 77 crankshaft pulley...
banjoman09
11-21-2020 14:45:02
I did get my generator belt changed and fan belt back on- bit of a challenge- now the three nuts on the pulley I did loosen and it never moved more than 1/2" and now trying to get it to move back to tighten belt but not going- I would think it would move? Thanks.
Olliejunkie
11-21-2020 21:14:05
 Re: Oliver 77 crankshaft pulley... in reply to banjoman09, 11-21-2020 14:45:02
It seems to me you could free it up by removing the 3 bolts and working but I would have to look at one to verify.
Spunky Flat Ron
11-21-2020 17:49:14
As Olliejunkie said, it will be necessary to remove the pulley and take the slip ring off. You may even need to rent a gear puller from Autozone or someplace to get the adjuster ring off without damaging it. Your pulley is probably beat up from previous adjustment actions. You will need to use various tools to smooth out the damage. My theory is that these pulleys were often adjusted while the tractor engine was hot (Probably overheated). To further speculate, the main part of the pulley was getting a lot of heat from the engine and expanding more than the adjustment ring which was exposed to moving air. This would effectively lock up the pulley assembly. I think this explains why you see so many pulleys on Fleetlines (66, 77, 88) beat up and difficult to adjust. Oliver had to stay with this design so they could fully cover the engine compartment with sheet metal. A typical single V-belt arrangement would often throw the generator into interference with the side panel.
banjoman09
11-21-2020 18:12:20
 Re: Oliver 77 crankshaft pulley... in reply to Spunky Flat Ron, 11-21-2020 17:49:14
I see and that's probably the way to do this- might be a rainy or snowy day before I get to it! I will have to remove the hood and the from metal and the radiator. Thanks.
Olliejunkie
11-21-2020 14:56:48
Last one I did I took apart and either greased it or used anti sieze on it.
banjoman09
11-21-2020 16:07:23
 Re: Oliver 77 crankshaft pulley... in reply to Olliejunkie, 11-21-2020 14:56:48
Yeah I think it is kinda stubborn! I used some WD but didnt help any.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: Lookingfor used pipe reamer [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
