Got the Ollie 55 diesel home out of the weeds and brush that grew up around it. The engine is seized. Was going to fill the cylinders with transmission fluid and acetone. Removed fuel lines and injector stud bolts. Manual says "carefully remove injectors from cylinder head". Injectors aren't budging.
On the opposite side of the block are 4 cap screws. Do these cover the end of the injectors? Can I tap the injectors out from the opposite side? Any suggestions appreciated.
