Oliver 1750 front weights
I had a Olive base but don't know what tractor it fits. I'll have to go look for it. I have no use for it. Where you located?
I'm lower Michigan. Haven't seen it in ten years but I'm sure its out in a barn. If you interested in just it let me know.
(quoted from post at 06:35:50 09/28/20) I had a Olive base but don't know what tractor it fits. I'll have to go look for it. I have no use for it. Where you located?
Part number is 1592420A
The early base weights will have a different part number. The reason is they will not be drilled and tapped with the 4 holes to accept the flat weights that were introduced with the front wheel assist tractors. Part numbers for both old style and later base weights will be on the weights.
did you ever find your front weight base?
I didn't hear from you so I never went to look for the one I had.
