Kubota zg23 deck lift cylinder
rrman61
Is there a separate bypass for the deck lift cylinder or is my cylinder by passing?its been losing lift for awhile.i
changed the hydraulic filter with no effect.i.can hear it trying to lift but not as loud as when it was working right .is
there a way to pinpoint the problem?
If it's an older ZD with 500 plus hours your looking at a new pump and drive motors. Kubota knew they had a problem child but most made it out of warranty before they would blowup. 5 years ago it took $2500.00 to fix it. BTDT. Good Luck.
No everything else works fine only the lift and since it’s only to
adjust the cutting height I can live with it.only asked about it if
it would have been an easy fix (inexpensive lol on a Kubota)
