super99
Does anyone have a operator’s manual for one? I would like to know what the rear wheel is supposed to be set at. I had to slide my drawbar to the right to get the plow lined up with the furrow. The plow is adjusted as far as it will go and still doesn’t line up right. Looks like I’ll have to move the fender to the inside of the mounting bracket in order to move the wheel in far enough to get a straight pull. Any suggestions?
   If two beams come to the front cross bar it's a 4240, 2 or 3 bottom.   If three beams come to the front cross bar it's a 4340, 3 or 4 bottom.
